Cybersecurity vulnerability CVE-2026-109618 and CVE-2026-109619
Are the PFC100/PFC200 concerned by theses PHP vulerabilities CVE-2026-109619 and CVE-2026-109618 ?
Did Wago already published a patch/fix about this for the concerned hardware ?
Thank you all,
Hi LotfiH.
On the downloadcenter there is an .IPK Patch to adress this.
(the site is really slow atm)
Best Regards Jan
Thank You WagoJan for your feedback,
Does it mean that only PFC’s with Firmware 31 are concerned by this vulnerabilities or its all PFC’s with fimrware version under 4.9.1 (FW31) and actually the security fix is only applicable for FW31?
Thank you for the feedback,
Hi LotfiH.
Good question.
Try and read this artikel related to it.
It might affect lower firmware versions also, but the fix is only available for FW31 until FW32 is released
Thanks a lot for your feedback,
i think it concerns all applications no matter which firmware versions for all applications using an integrated web server,
but the remaining question is is the wbm also concerned by this vulnerability ?
