Hi @espenbo ,
For this purpose, the SAX parser of the WagoAppJSON is perfect.
You just need to define the token, and the associated rule to process the string data.
You’ll find attached the way to implement it in your example.
eCockpit_Json.txt (139.7 KB)
(This is an export file change the extension file to .export)
Set xTriggerJSONParser to start the parsing process.
