# How To: Using PFC200 Onboard Serial Port with Node-RED
**URL:** <https://www.wago.community/t/how-to-using-pfc200-onboard-serial-port-with-node-red/68>\
**Category:** Node-RED\
**Tags:** pfc200, serial\
**Created:** [May 26, 2022, 10:09pm UTC](https://www.wago.community/t/how-to-using-pfc200-onboard-serial-port-with-node-red/68 "2022-05-26T22:09:05Z")\
**Posts on this page:** 1\
**Showing post:** 5
<div class="post-metadata">
**Author:** ![WagoIcard](https://sea2.discourse-cdn.com/flex016/user_avatar/www.wago.community/wagoicard/32/1508_2.png) [@WagoIcard](https://www.wago.community/u/WagoIcard)\
**Post date:** [June 21, 2023, 1:47am UTC](https://www.wago.community/t/how-to-using-pfc200-onboard-serial-port-with-node-red/68/5 "2023-06-21T01:47:47Z")
</div>
Here is a possible fix:
> - I you don’t have Portainer:
> Login in the CC100 with SSH then go to elevated user by using the command `su -`
> Then use the command `docker exec -ti --user root <containername> /bin/bash` to open the container console as root.
> - If you have Portainer, use it to log in the container console in root.
> - In the container console, go to the node-red data folder `cd /data/`
> - Execute the command `npm rebuild --build-from-source`
> This will rebuild the serial node from source to the specific of the CC100 system.
_[View the full topic](https://www.wago.community/t/how-to-using-pfc200-onboard-serial-port-with-node-red/68)._
