Does anyone know of a command to mount an SD card from the command line? The objective is to automate the configuration of a Wago PLC using a script.
Thanks in advance
Thanks in advance
I don’t really understand the question. The SD card is on automount already. What do you want to do ?
I’ve managed to find a solution that I’m currently testing.
I needed to format, name, and mount SD cards via a script to automate the production deployment of repetitive automation tasks.
Best regards
