I spent quite some time trying to get Runtime User Management to work before coming across an older discussion mentioning that the WAGO devices (even FW30) may not support it. Could you please confirm if this is still the case?
I want to make sure I’m not missing any required configuration or known limitation.
I initially attempted to implement Runtime User Management without success, so I switched to the legacy Visualization User Management. However, I am still facing issues with both approaches.
The Visualization User Management works correctly within the CODESYS IDE, but it does not work when accessing the WebVisu through a browser.
I am currently using FW30 on a WAGO CC100 and accessing the WebVisu via:
https://192.168.15.179:8081/webvisu/webvisu.htm?CFG_Lang=pt&BRLG&NOSP&RLLG
Additionally, I would like to clarify whether the configuration below should be commented out when using the legacy Visualization User Management. Is this configuration only relevant for Runtime User Management?
[CmpUserMgr]
SecureLogin=1
SECURITY.UserMgmtAllowAnonymous=YES
Any guidance would be greatly appreciated.
