CC 100 OpenVPN Configuration via SSH
Hello everyone,
We are already using OpenVPN with the CC100. With the additional information from this forum and the YouTube how-to video (https://www.youtube.com/watch?v=H4c7NQiCalk) regarding the extra OVPN config lines
pull-filter ignore ifconfig-ipv6
pull-filter ignore route-ipv6
pull-filter ignore ‘redirect-gateway ipv6’
as well as log
/var/log/openvpn.log
the connection works reliably after a reboot.
Our question is now the following:
Is it possible to deploy the profile configuration without using the UI (WBM > Security > OpenVPN / IPsec), for example by copying it to the controller via SCP, and then configuring it via terminal (SSH) to
  1. store the configuration, and
  2. enable OpenVPN using the previously stored profile configuration?
What commands would be required for this?
Our goal is to perform this step without any user interaction (UI).
Thank you in advance!
Everything what you can do from WBM you can do by scripts from /etc/config-tools (thats how WBM works, it runs scripts using php). So there is /etc/config-tools/vpncfg
/etc/config-tools ./vpncfg --help
Usage: vpncfg -h|--help
       vpncfg vpn CMD
       vpncfg VPN CMD
       vpncfg crt CMD
       vpncfg file CMD [OPTIONS]
 Basic commands:
  -h, --help                prints this help
 vpn - general commands:
  vpncfg vpn CMD
    --get-full-status       returns all status information using json format,
                            including the list of certificates from --get-cert-command
 VPN - OpenVPN/IPsec common commands:
  vpncfg VPN CMD            executs command for a selected type of vpn framework.
                            VPN can be set to either ipsec or ovpn and there are
                            the following types of CMD commands:
    --is-enabled            returns enabled|disabled if VPN is started on boot
    --enable                enables VPN on boot
    --disable               disables VPN on boot
    --is-running            returns running|stopped status of the VPN
    --start                 starts VPN service
    --stop                  stops VPN service
    --restart               restarts VPN service
    --reload                orders VPN to reload configuration files
 crt - certificate commands:
  vpncfg crt CMD
    --get-list              returns a list of certificates using json format
 key - private keys commands:
  vpncfg key CMD
    --get-list              returns a list of private keys using json format
 file - file commands:
    --store FILE SRC_FILE
                            copies content of a file designated by SRC_FILE to its
                            correct name. If the file already exists it will be
                            overwritten. FILE parameter names a type of a file
                            which might be one of: cert, key, ipsec.conf, ipsec.secrets
                            openvpn.conf. Source files shall be stored inside
                            /tmp/vpncfg/ directory.
    --read FILE             drops content of a file on std out. Allowed are the following
                            FILE values: ipsec.conf, openvpn.conf.
    --remove FILE [NAME]    removes a file completely. In case of the FILE argument
                            allowed are all values from --store command, but in case
                            of the cert and key files also NAME of the file must be given.
    --copy FILE USER GROUP  copies content of a FILE to a /tmp/vpncfg-out/FILE location.
                            The copied file will be owned by USER:GROUP with access
                            rights set to 0600.
Example:
  vpncfg ipsec --is-enabled
  vpncfg file --store cert user_certificate.pem
                            The full source file path is:
                            /tmp/vpncfg/user_certificate.pem
You can also edit directly OpenVPN config file: /etc/openvpn/openvpn.conf and then just reload configuration and enable OpenVPN with commands
@WagoDamRud,
thank you very much for your detailed explanation.
We were aware that /etc/config-tools is used in the background; however, it only became clear through your response that vpncfg is the corresponding script behind it. This clarification was particularly valuable for us. With this insight, and the additional guidance from the --help description, we are now able to proceed effectively.
