Convert functionblock from codesys 2.3 to 3.5 bacnet
I’m trying to convert my codesys 2.3 function block to e!cockpit.
The function has 3 inputs from a physical switch Auto/Off/On. And Virtual Switch from HMI/BMS system on Bacnet. When the physical switch is in Auto then the virtual switch can be used to set auto/Off/On. But if the physical switch is in Off or On it should write to tha bacnet multistate value priority 10 and not let HMI/BMS do anything. They use priority 13.
I have thise working in codesys 2.3 but I need help converting it to e!cockpit
(*Codesys 2.3 This function block collects BacNet Multistate value values.
1 = Switch SD/VenderAuto
2 = Switch Off
3 = Switch On
The values say what position the turner is in.
The block writes the value in priority 10 when ON(3) or OFF(2).
When selected auto(1), the value in priority 10 is reset and the top system can take control.*)
VAR_IN_OUT
	bacVenderValue		:Bacnet_Multistate_value;
VAR_INPUT
	VenderOff		: BOOL;
	VenderOn		: BOOL;
	VenderSD		: BOOL;
VAR_OUTPUT
VenderValue			:DWORD;		(*Physically facing in blackboard. 0-IB, 1-Auto, 2-Off, 3-On*)
	VenderValuePRI		: FbBACnetPriorityArray_MV;	(*Feature block to be able to zero priority 10*)
	dwValue				: DWORD := 0;	(*Default value *)
	bPriority			        : BYTE := 10;	(*Priority, if 0 the function block will be disabled*)
	dwPresentValue		: DWORD;		(*Present value*)
	xOverride			: BOOL;			(*Override signal. TRUE->Present value is an override value*)
	xError				: BOOL;			(*TRUE-> Out of range. dwValue> Number of states*)
	xNull				: BOOL;			(*Resetter prioritet 10 verdier "NULL" TRUE->NULL*)
	IF (VenderSD = TRUE) AND (VenderOff = FALSE) AND (VenderOn = FALSE) THEN
	(*AUTO*)
		IF (xNull = FALSE) THEN
			xNull := TRUE;
			VenderValuePRI(
				dwValue:= 0,
				xNULL:= xNull,
				bPriority:= bPriority,
				BACNET_MULTISTATE_VALUE:= bacVenderValue,
				dwPresentValue=> dwPresentValue,
				xOverride=> xOverride,
				xError=> xError);
			END_IF
		VenderValue := 1;
	ELSIF (VenderSD = FALSE) AND (VenderOff = TRUE) AND (VenderOn = FALSE) THEN
	(*OFF*)
		bacVenderValue.priority_array.PriorityArray[10].CHOICE :=3;
		bacVenderValue.priority_array.PriorityArray[10].Value :=2;
		VenderValue := 2;
		xNull	:= FALSE;
	ELSIF (VenderSD = FALSE) AND (VenderOff = FALSE) AND (VenderOn = TRUE) THEN
	(*On*)
		bacVenderValue.priority_array.PriorityArray[10].Value :=3;
		VenderValue := 3;
		xNull	:= FALSE;
	ELSE
	(*IF undifined - OFF*)
		VenderValue := 2;
		xNull	:= FALSE;
	END_IF
Going from Codesys 2.3 to e!Cockpit / Codesys 3.5 is not difficult,
Here is a sample which should act like the one for 2.3:
** e!Cockpit / Codesys 3.5 This function block collects BacNet Multistate value values.
** 1 = Switch SD/VenderAuto
** 2 = Switch Off
** 3 = Switch On
** The values say what position the turner is in.
** The block writes the value in priority 10 when ON(3) or OFF(2).
** When selected auto(1), the value in priority 10 is reset and the top system can take control.
VAR_IN_OUT
bacVenderValue : WagoSysBACnet.FbMultistateValue_medium;
VAR_INPUT
VenderOff : BOOL;
VenderOn : BOOL;
VenderSD : BOOL;
VAR_OUTPUT
VenderValue : DWORD; (* Physically facing in blackboard. 0-IB, 1-Auto, 2-Off, 3-On *)
(AUTO)
IF (VenderValue <> 1) THEN
bacVenderValue.IPriorityArray.SetPriority(ePriority := 10, udiValue := 0, xNull := TRUE);
END_IF;
VenderValue := 1;
(OFF)
IF (VenderValue <> 2) THEN
bacVenderValue.IPriorityArray.SetPriority(ePriority := 10, udiValue := 2, xNull := FALSE);
END_IF;
VenderValue := 2;
(On)
IF (VenderValue <> 3) THEN
bacVenderValue.IPriorityArray.SetPriority(ePriority := 10, udiValue := 3, xNull := FALSE);
END_IF;
VenderValue := 3;
ELSE
(IF undifined - OFF)
END_IF;
VenderValue := 2;
END_IF;
If somebody finds t usefull
I use virtual switches in HMI panles to. 1 = Auto, 2 = Off, 3 = ON.
They use one wirte priority on the panel and a other on the BMS system. HMI (10) BMS (13)
I made a function block that resetts values on priority 10 when you set it to 1.
FUNCTION_BLOCK FB_SD_Vender_Virtuel
VAR_IN_OUT
VAR_INPUT
VAR_OUTPUT
	udiPresentValue		: UDINT; // save last value
	xChange				: BOOL;  // Presentvalue not changed
	iChange				: INT;	// Number of changes
IF bacVenderValue.udiPresentValue = udiPresentValue THEN
	xChange := FALSE;
ELSE
	xChange := TRUE;
	iChange := iChange +1;
	udiPresentValue := bacVenderValue.udiPresentValue;
END_IF
IF xChange = TRUE THEN
	bacVenderValue.Read(WagoTypesBACnet.eBACnetPropertyUpdateGroup.GROUP_ON_TRIGGER);
END_IF
IF bacVenderValue.IPriorityArray.aLevel[10].udiValue = 1 THEN
END_IF
