Could not Read data from 2 slave Modbus RTU
In status tab.
What is the last error ?
The one that im showing is already in status tab.
Click (+) Last Error and see details
Owh, my bad. This is what it says
Absolutely. Nothing in progress.
And why is that happening ? Should be no problem since I can read the data using Modbus RTU function block. Is it?
Your application seems to be stopped.
Start your program and check status / error messages again.
Now “Response CRC Fail” appeared.
Sometimes work for me
Add polling time. Try 5 seconds at first.
how do you add that polling time?
Finally, I am able to read the data from Modbus Configurator. The solution is only to change the cable from normal cable to profinet cable.
Thank you for your suggestion all this time.
