How To: Edge Computer with 3rd Party Touch Screen in Kiosk Mode
How to use a 3rd party touch screen with the Edge Computer in Kiosk Mode. This would be useful for CODESYS-based web visualizations or Node-RED Dashboard for example.
HowTo Edge Computer Touch Screen.pdf (3.6 MB)
There is a typo in step 3.2. It should read;
mkdir -p /home/kiosk-user/.config/openbox
Updated kiosk mode steps
sudo apt update
sudo apt upgrade
useradd -m kiosk-user
sudo apt-get install xorg chromium openbox lightdm
nano /etc/lightdm/lightdm.conf
Add under section [Seat]:
[Seat:*]
autologin-user=kiosk-user
autologin-user-timeout=0
session=openbox
Save [Ctrl-X]
sudo /etc/init.d/lightdm restart
Add plugin to browser called: LKWFahrer_300KMH
Change to english keyboard using icon in address bar and change to popup mode
nano /home/kiosk-user/.config/openbox/autostart
Add to this blank file:
xset -dpms &
xset s off &
chromium --kiosk “http://192.168.2.17:8080/webvisu.htm” &
Save [Ctrl-X]
Hi Kurt.
We had a similar problem with the TP600 not being able to show specific webpages. My quick solution was to install Firefox as a Docker container. It was easy to setup and the TP600 was fine with showing the containers GUI.
Just another solution for the TP600 or other panels to show more complex webpages
Best regards.
Jan
I’m interested @WagoJan!
Where you able to attach the touchscreen also ?
Anyhow the upcoming FW30 will have a updated web browser that will make life easier for us :slight_smile:
For clarity, these instructions are for the WAGO IPC running debian.
So i installed the Firefox Docker on the Edge Computer, and i then i just have the TP600 look at the IP address and Port of the container.
I did try to have the container installed on the TP600 Control panel itself. It worked, but it was really slow on responce.
