Create a directory on the PFC200 that you wish to use as your working directory.
Create a Dockfile in that directory containing:
FROM mcr.microsoft.com/dotnet/sdk:6.0-bullseye-slim-arm32v7 AS build
WORKDIR /app
RUN dotnet new console
COPY MyFile.cs Program.cs
RUN dotnet publish -c Release -o outFROM mcr.microsoft.com/dotnet/runtime:6.0-bullseye-slim-arm32v7
WORKDIR /app
COPY --from=build /app/out .
ENTRYPOINT [“dotnet”, “app.dll”]
Create a C# program in that directory and save as MyFile.cs or use the simple program below:
// C# program to print Hello World!
using System;// namespace declaration
namespace HelloWorldApp {// Class declaration class Geeks { // Main Method static void Main(string[] args) { // statement // printing Hello World! Console.WriteLine("Hello World!"); // To prevents the screen from // running and closing quickly Console.ReadKey(); } }}
You can name the C# program as you wish, just make sure the Dockerfile matches.
Run the following command to build the docker image:
docker build -t myimagename:arm32v7 .
Run the following command to test the Hello World program:
docker run -it myimagename:arm32v7
All the files and commands should be in the same directory.
Acknowledgement: Thanks go to Joe A. for his help in figuring this out.
