PFC200 No Application after reboot
Hello
I have a PFC200 (750-8214) which I have upgraded the firmware to V040601_28.
My problem is that it will not load the application after a reboot.
By switching System (Internal Falsh) it now running the “old” firmware 04.04.03(26).
The problem is the same, application is not loading.
There is no SD-card installed.
I’m using testet in “CODESYS V3.5 SP20 Patch 3” and “CODESYS V3.5 SP20 Patch 4”
I have previous used PFC100 with firmware 04.04.03(26) and CODESYS V3.5 SP20 Patch 3, without any problems.
From the log message, Source: Standard
Fri Jan 17 2025 10:47:19.063306 init: System Booted
Fri Jan 17 2025 10:47:24.006195 CODESYS_3: KBus is booting
Fri Jan 17 2025 10:47:26.271533 CODESYS_3: KBus has booted.
Fri Jan 17 2025 10:47:26.277054 CODESYS_3: KBus is operational
Fri Jan 17 2025 10:47:26.332374 CODESYS_3: The PROFIBUS DP device has not been opened
Fri Jan 17 2025 10:47:26.336343 CODESYS_3: The PROFIBUS DP device has not been opened
Fri Jan 17 2025 10:47:26.402387 CODESYS_3: The PROFIBUS DP device has been closed
Fri Jan 17 2025 10:47:27.138259 CODESYS_3: PLC is online and no program is loaded
Fri Jan 17 2025 10:47:27.766792 CODESYS_3: Application stopped
Fri Jan 17 2025 10:47:27.937438 CODESYS_3: PLC: KBUS configuration mismatch
Wago Codesys add-ons:
What can I do, to fix this?
Edit:
Just to clarify, I can download a application from Codesys, and its will run without any problems, until a reboot.
The fix, in Codesys
The PLC did not have a “Boot application”.
after creating a boot application, everything now working as intended.
