Hello everyone,
I want to read the time out of my CC100 in Codesys. I tried several Function-blocks (SysTimeRtcGet, SysTimeGet, …). Does someone know what I could do wrong or what I should try next?
Thank you very much
Noah
Hello everyone,
Thank you very much
Noah
Hello Noah,
You can use the following functions from the WagoAppTime library:
FuGetLocalDateAndTime to retrieve the local date and time
FuGetDateAndTime to retrieve the UTC date and time
FuGetSystemTime to retrieve the system time
Best regards,
Paul
Hello Paul
Thank you for the fast response.
I now did a function block and named it FuGetLocalDateAndTime. at the right side I connected a variable in the format DT. But there is a problem report that FuGetLocalDateAndTime is not defined. Do you know what the problem is?
again Thankyou so much
Best regards
Noah
Thankyou very much now it works. I didn’t know that it was a function and not a function block. But I have another little problem: I now have a variable in DATE_AND_TIME Format. My goal is to set a flag everyday at 00:00 o clock. How can I do this?
