Visu Custom Widgets in HTML5
Hi all,
I would like to ask if someone have a good instruction/tutorial about creating custom widgets in HTML5 so that is could use it in visu ? Thanks in advance.
Hello
You can follow this CODESYS Visualization Series | Part 8/9: HTML5 controls serie and also download example projects from here CODESYS Forge - HTML5-API-Examples / Home / Home
You should first install the xml file to the system under tools/Visualization Element Repository.
Hi, I did watched this short episode on youtube (3 minutes ) but i tought more about a stap for stap tutorial while i still not getting how do i begin from scratch if i want to create my own widget. I think i just needs to search further and try find it out.
