WBM Docker status error on cc100
I using docker on CC100 controller for a couple weeks ,everything is good.
Because I didn’t change root-data in daemon at first when I built project, so I changed it after removed all docker image. Then my docker became not work even I re-install every thing again. Does anyone know how to resolve this problem.
Sincerely.
Allen
did you copy docker files to new place before trying to run it?
WAGO/docker-ipk: Move docker “DATA-ROOT” to the SD card
you can always just run in PuTTY
opkg remove docker
and repeat everything
It’s work again
Thanks very much
