Is it possible with the 494 PowerMeasurementCard to use Voltage transformers for Medium Voltage applications?
I saw these in the typ494config FB but they dont seem to have any effect.
What is your problem? What and where transformers do you want to use?
I want to do medium voltage measurements (10kv) with voltage and current transformers.
I have never worked with such high voltage. I won’t give you any advice here.
Hello Technically, this should be possible.
In order to be sure please contact your wago sales services. they should be able to give you the right answer and how to make it work.
