I’m currently attempting to request data from the Wago WDA API but am constantly getting a bad request or timeout.
The documentation refers to the hostname/wda on port 443
Looking at our /etc/services I find that port 443 is the HTTPS port:
I’m also able to grab the openapi json string in the documentation via 192.168.1.35/openapi/wda.openapi.json
I’ve set the GET HTTP request settings to point to the port and file wda:
I’ve tried with and without authentication with no success. The Authentication parameters I’ve used are the login and password for ssh/wbm connection (root,wago).
I still receive these errors from the GET command and am unsure why:
As a last ditch effort, I’ve disabled the firewall for HTTPS and ensured that the service is enabled but still nothing.
Does anyone have any ideas on the correct configuration to access the API?
Thanks!
