Auto Run Application
Hej,
I am trying to write a code to auto restart the application after cold restart. I cannot find a command for this in the libraries and was therefore trying to use startprg shell command, but this does not work either. Anyone, who has done this before?
I’ve not tried it but you could try to use the system events, “DownloadDone”
To start the app there is a lib WagoAppControl which could help.
This is the easiest solution, i could think of but you need to test it to be sure it can be done this way.
Hej Rob,
Sorry for the late reply. Thanks for the hint. See below solution. I tested it and it works like a charm. Just requires a bit of battling around with the libraries.
