Autorun shell script at startup
Hey, is there a possibility to run a shell script at system boot. (preferably without triggering this from codesys runtime)
This would be a PFC with FW~28.
Hello Simon,
There is in the following a description on how to do it for the wpa_supplicant for 802.1x.
See the page 116, chapter 7.2.3
Hope it helps,
Place your script in /etc/init.d
Then create a symlink in /etc/rc.d
ln -s /etc/init.d/myscript /etc/init.d/S99_myscript
The number in the symlink will define in which order the script will be called (for instance before or after the runtime…)
