Is it possible to change the default port 11740 CODESYS protocol uses? I am connecting Kepserver using the CODESYS driver and the default is 11740. I would like to change this.
Is this somewhere in the CODESYSControl_User.cfg?
I know you can set a port forward in the WBM, but would like to avoid this.
