Is it possible to embed one controller’s webvisu into the webvisu or target visualization of another controller? I would like to pool visualizations in some sort of tile configuration.
apparently it is: In order to display one webvisu (following named Target) in another webvisu (following namend Master) the following steps must be taken:
- Go to the Target and Master WBM and open the same http/https ports in Ports and Services (Best practice: Open just http or https)
- Log in to the Target using FTP (e.g. WinSCP, name: root, password: wago) and navigate to the folder /etc/lighttpd
- a) Open the files “mode_http.conf”, “mode_http+https.conf” and “mode_https.conf” and remove the line
setenv.add-response-header += (“X-Frame-Options” => “SAMEORIGIN”)
This will allow anyone to display the visu in a frame
b) (just if needed)
Change the line to setenv.add-response-header += (“X-Frame-Options” => “SAMEORIGIN”)
to "ALLOW_FROM insert ip adress of pc " to allow acces with frames from this PC. - Restart the Target
- In the Master webvisu call the Target in the webbrowser element with http:// or https:// according to 1)
- Call the Master webvisu in the browser with http:// or https:// according to 1)
This is the same workflow if you want to embed the visualization in a Grafana Text Panel.
You need also to set the parameter “-e GF_PANELS_DISABLE_SANITIZE_HTML=true” when creating the Grafana container.
I have tried this way. However, I do not have the “setenv.add-response-header += (“X-Frame-Options” => “SAMEORIGIN”)” in my target. Instead, it is “setenv.add-response-header += (“Strict-Transport-Security” => “max-age=15768000”)”. I am using PFC200.
I am trying to use this method to help me with displaying IP camera feed within webvisu web browser element. Unfortunately, it can’t display any URL/Website other than its own WBM.
So, I am struggling it looks like the web browser element does not work properly so I can’t access to the IP camera as well.
Late reply but you can find the line in here now: /etc/lighttpd/apps.confd/webvisu.conf
