What’s the best way to install Python to 750-8212 PLC (with FW26)?
Hello, depending on the python build i would recommend using docker.
Hi @pehaa ,
you can use an image from dockerhub to use python functionality for the PFC.
https://hub.docker.com/repository/docker/wagoautomation/python/general
Alternatively, you can create a dockerfile to add the required Python & libraries to an Alpine base image.
Something like this;
FROM alpine:3.19
# This hack is widely applied to avoid python printing issues in docker containers.
# See: https://github.com/Docker-Hub-frolvlad/docker-alpine-python3/pull/13
ENV PYTHONUNBUFFERED=1
RUN echo "**** install Python ****" && \
apk add --no-cache python3 && \
if [ ! -e /usr/bin/python ]; then ln -sf python3 /usr/bin/python ; fi && \
echo "**** install pip ****" && \
rm /usr/lib/python3.11/EXTERNALLY-MANAGED && \
python -m ensurepip && \
rm -r /usr/lib/python*/ensurepip && \
if [ ! -e /usr/bin/pip ]; then ln -s pip3 /usr/bin/pip ; fi && \
pip install --no-cache --upgrade pip setuptools wheel
This is the first time I encountered this and I will say that I succeeded. If you need an installer (750-8208) I can tell you. and tell me how to do it.
