No supported container engine found in device
Trying to connect to pfc200 and keep getting this message , no support container engine found on device. You have to install a supported container engine to use virtual control . Please contact the administrator.
Also get error detecting container architecture.
I have manage to install codesys control for pfc200 Sl
And codesys edge gateway for Linux
Any help on what I should do next would be good
It looks you are trying to use Virtual Control SL (Dockerized runtime) on a PFC200.
This is not possible.
You don’t need either CODESYS Control for PFC200 SL
The CODESYS runtime is part of the firmware so you don’t need that.
Install the Device Description and select the right target : WAGO Download Center
Sorry im a little confused, and not to sure what to do. i have a pfc200 and and i have downloaded codesys v3.2 SP19 Patch 7 and want to be able to upload a ladder logic program to the pfc 200. I have look at videos online but i have had no luck, Any help would be awesome
Go to the web interface of the PLC and see what version is installed, you can send me a screenshot here and I will tell you what to do next.
is this enough or do you need more, currently having issues trying to assign it an ip address and then use web interface
The PFC200 G2 firmware was e!COCKPIT and CODESYS 2.3 until version 22.
You should update your PFC to the latest version available here :
If you want it to work like this, you need to install version 28 (the latest version at the moment) instead of 18 and then you will be fine. Download the firmware, upload the file to your flash drive and you should be fine. If you have any questions be sure to write, we will help you.
i am still having the issue where Invalid user authentication on the device and i though i had updated everything to be compatible. i can see the deivce when i ping it and when i log into web management, but now since i have updated the device to run on codesys latest one i can connect
Can you be more specific? Where do you want to connect? How is everything going? I understand that you have updated the PLC. What’s next?
