How To: Using PFC200 Onboard Serial Port with Node-RED
Here is a possible fix:
  • I you don’t have Portainer:
    Login in the CC100 with SSH then go to elevated user by using the command su -
    Then use the command docker exec -ti --user root <containername> /bin/bash to open the container console as root.
  • If you have Portainer, use it to log in the container console in root.
  • In the container console, go to the node-red data folder cd /data/
  • Execute the command npm rebuild --build-from-source
This will rebuild the serial node from source to the specific of the CC100 system.
