Installing Windows 11 LTSC on Wago 752-9813 Edge PC
I put together a short guide for installing Windows 11 IoT Enterprise LTSC on a WAGO Edge PC, mainly to help with the oversized Windows setup screens you can run into before the graphics driver is installed. The guide walks through creating the USB installer, booting from USB, getting past the difficult-to-see setup UI, using Windows Update to load the graphics driver, and then finishing setup.
This was made around a WAGO Edge PC 752-9813, but it may also be helpful for others working through a similar Windows 11 install experience on WAGO Edge PCs. The guide covers the key workaround of switching to the previous version of Windows Setup so the installer is usable before the graphics driver is loaded, then updating drivers once you reach the desktop.
Edge PC Win11 Install.pdf (1.7 MB)
After initial windows setup some chipset drivers and ethernet adapter drivers needed to be installed for the NICs on X2, X11, and X12 to function. These drivers can be downloaded from Intel at these links:
