IPv4 forwarding in PFC200
When using the PFC200 in an environment where the IP address can change, it may be necessary to enable a feature called IPV4 forwarding. This is done with the following steps.
  1. ssh into the controller (PFC200)
  2. Type:
    nano /etc/sysctl.conf
  3. Find the line that reads
    #net.ipv4.ip_forward = 0
    change to
    net.ipv4.ip_forward = 1
  4. Save the file with Ctrl-X and Y.
  5. Reboot the PFC200.
image (14)
Hi Kurt,
I thought this parameter was overwritten by the WBM ?
(It doesn’t follow the /ets/sysctl.cnf value though but have the same effect ?)
I found it also possible by entering lines:
  1. sysctl net.ipv4.ip_forward to check its current value
and
  1. sysctl -w net.ipv4.ip_forward=1 to enable it (=0 to disable)
  2. reboot
  3. confirm that forwarding is enabled by running first command again
