Hello everyone,
I’m encountering an issue when trying to load a configuration file using the CLI that contains various settings. Everything seems to work correctly, except for the OPCUA settings.
For example, if I save a configuration file with:
/etc/config-tools ./settings_backup save /tmp/savedConfig.config
Then, I modify the file’s content, such as the hostname or IP address, and restore it with:
/etc/config-tools ./settings_backup restore /tmp/savedConfig.config
The changes are applied successfully, except for the settings within the JSON string config_opcua. These settings don’t get updated.
The same issue occurs when I try to use:
/etc/config-tools/backup-restore ./opcuaserver-backup --save /tmp/myopcua.config
I then change the ctrlConfigurationName variable and run:
/etc/config-tools/backup-restore ./opcuaserver-backup --restore /tmp/myopcua.config
But the changes are not applied.
However, if I use:
/etc/config-tools/config-opcua --set="ctrlConfigurationName":"MY\ NAME\ WITH\ SPACES"
The OPCUA name is set correctly.
When I run:
/etc/config-tools ./config-opcua -G
I get the following output:
{"state":"enable","port":4840,"logLevel":"error","unlimitedAccess":"enable","trustAllClients":"enable","applicationUriCheck":"enable","errorCertificateTime":"disable","certificateIssuerTimeInvalid":"disable","certificateRevocationUnknown":"disable","certificateIssuerRevocationUnknown":"disable","endpointUrlInterface":"hostname","securityPolicyNone":"enable","securityPolicyBasic128_Rsa15":"enable","securityPolicyBasic256_Sha256":"enable","serverVersion":"1.3.2","serverLicense":"–","informationModel":"disable","informationModelDesc":"","ctrlConfigurationName":"MY NAME WITH SPACES"}
If I then change the name and use the -S option like this:
/etc/config-tools ./config-opcua -S {"state":"enable","port":4840,"logLevel":"error","unlimitedAccess":"enable","trustAllClients":"enable","applicationUriCheck":"enable","errorCertificateTime":"disable","certificateIssuerTimeInvalid":"disable","certificateRevocationUnknown":"disable","certificateIssuerRevocationUnknown":"disable","endpointUrlInterface":"hostname","securityPolicyNone":"enable","securityPolicyBasic128_Rsa15":"enable","securityPolicyBasic256_Sha256":"enable","serverVersion":"1.3.2","serverLicense":"–","informationModel":"disable","informationModelDesc":"","ctrlConfigurationName":"newNAME"}
The name is not updated. Is there a bug in the config-opcua script, or could it be related to another setting in the JSON string?
I’m using a WAGO 750-8212 PFC200 G2 2ETH RS XTR with firmware version 03.10.10(22).
Thanks in advance for any help or insights!
