After i put the one code string in subprograms Generated Code which are created by the Modbus Master Configurator. After all Modbus RTU connections goes to Timeout.
Nothnig help - reset PLC, load old version and change PLC. Please help
Dear colleague! I made remove code and generate again. it does not work . Then i made new empty project and create code only for Modbus connection with one pump. also not working.
it seem to me such problem more deep inside in PLC or 750-653 module ! I have great problem in my job cause of it. Please HELP! I can send project file.
Hello Arsenio,
Could you get in touch with the WAGO technical support of your country ?
I think they should be able to help you way faster than here.
Dear Colleague! According with your advice i send email to technical support. Also i am moving in parallel way. I don’t use Modbus configurator. I took a Modb_l05.lib library and configure Modbus Master RTU CFC module. Maybe you know what is type of variable typRING_BUFFER which is mentioned there?
ReceiveBuffer : typRING_BUFFER;
SendData : typRING_BUFFER;
Hello !
Have you tried to establish a connection with your pump using software like ModRSsim for example?
Hello! I have using ModLook and Moxa Uport from my PC to Pump. It works. I received data and control pump. I have problem with connection between PLC 750-891 750-653 modbus module and direct to Pump. I supposed that you are offering to me connect my PC by Moxa Uport with 750-653 directly and analyze the protocol message TIMEOUT by ModRSsim software?
After reboot PLC XML communication with Weintek HMI is broken. How can restore XML? I made generate XML file for outside using and import in EasyBuilder. But its not working
Make sure that you have the 750-653/003-000 and not the 750-653. The 750-653 has 3 user data bytes and because of that, the module will not work for Modbus RTU communication.
it’s fact that all pumps have been controlled by Modbus 750-653/003-000 before my mistake. Everything was fine before i put string in to generated code. How can i load SW again? is there SD card in 750-891 like in PFC200? Or i need to download firmware from official site?
Maybe use IO Check to investigate settings inside the module.
