Hello
I have a problem with node-red…
I have installed node-red on a PFC300 PLC to send messages via Telegram, and I am also extracting data from a Compact Logix PLC, everything seems to be working fine.
It works for a few days and then stops working when entering the command “docker ps -a”, a message appears “node red exited (255)” and to get it working again it is necessary to restart node-red
When checking the node-red logs, it shows an error with the eth-ip communication node.
How can I make it so that if for some reason node-red stops and a restart is necessary, it does so automatically?
I hope you can help me
you can use --restart unless-stopped in docker run command Start containers automatically | Docker Docs
you can also change verbose of the logs. Edit file settings.js (if you are using docker, in volume /data you can find file /data/settings.js)
just add lines:
logging: {
// Console logging
console: {
level: "info",
metrics: false,
audit: false
Where you can choose level:
fatal - only those errors which make the application unusable should be recorded
error - record errors which are deemed fatal for a particular request
warn - record problems which are non fatal
info - record information about the general running of the application
debug - record information which is more verbose than info
trace - record very detailed logging
off - no log messages at all
