Reading a file (csv)
I want to read a file, CSV file line format:
27.11.2025 14:24:00 2569 24 2586 25
27.11.2025 14:24:01 2561 21 2586 26
How do I upload a file to the desired directory? Do I understand how to read such files? Can I read it whole or line by line?
Each line has a time, usually one second. I need to play this file (show it on visualization) according to the time.
I don’t need exact time, I need minutes and seconds to match.
I don’t know to what extent I described the problem correctly. Briefly: you need to play the file in a visualization.
You probably need to read this CSV and parse it into your own Dutch format.
You can then display it as a table in the visual.
I solved the issue using the SysFile library. She can do anything
