Is an example VAR declarations and Program code available for reading serial ASCII using the serial port on the 750-8212 PLC? Thank you.
Try this one:
Mr. Torgeir,
Thank you for the program code. I will obtain a serial communication card for the K-bus and give this a go.
You should be able to easily switch to the built-in serial port by using COM1 as the input interface of the function block.
Yes, thank you for your suggestion.
