SMS Control in WAGO PLC 750-8207
Hello everyone,
I’m working on a project using a WAGO PLC (model 750-8207), and I need help implementing SMS control for memory bits.
Goal:
I want to be able to send an SMS to a SIM module connected to the PLC, and based on the message content:
  • If the SMS says ONM0, it should turn ON memory bit M0.
  • If the SMS says OFFM0, it should turn OFF memory bit M0.
If anyone has:
  • An example program/code for this,
  • Experience integrating SMS communication with this PLC,
  • Or any guidance on how to parse SMS and control memory bits,
I would be very grateful for your support.
Thank you in advance!
Best regards
Are you using Codesys 2.3 or e!Cockpit ?
Also, possible duplicate with:
https://www.wago.community/t/sms-control-in-wago-plc-750-8207/2022
I am using codesys 2.3
I have this old sample and explication but I’ve never tried them:
GSM_SMS_01.zip (881.8 KB)
Thank you so much for sharing the sample and explanation. I really appreciate your help!
I’ll try it out and see how it goes. If I have any questions or need assistance, I’ll definitely reach out to you.
Thanks again!
