Wireguard for PFC
"Hello,
I was wondering if anyone has experimented with running WireGuard on a Wago PFC or CC. It would be great to have a WireGuard client running locally on the controller. Although OpenVPN is a viable option, I find WireGuard to be faster, more lightweight, and easier to use.
I attempted to install the WireGuard client from the OpenWrt repository, but unfortunately, the CPU architecture is not supported.
Thanks,
xxyzz
I have not tried Wireguard, but have had success with ZeroTier. In my experience is faster, and more simple to configure than OpenVPN. I have also seen others use Tailscale on a PFC200.
One of the Best Guidance. The vpn connection has succeeded. Thank u
I’ve made wireguard work on a PFC200 G2 using wireguard-go and thw wireguard-tools.
See notes below;
# Advanced: Compiling wireguard binaries
The included binaries are tested at PFC200 FW29, but there might be required new versions in future. These instructions would give a good inidication on how to do that.
## Requirements
Assuming working in a linux environment. The following routine has been devoloped from a windows computer, running WSL2 (Ubuntu 24.04.1 LTS)
The [WAGO PFC Firmware SDK](github) is needed for compiling the wireguard-tools binary.
In WSL:
- Firstly, update the system: `sudo apt update && sudo apt upgrade`
## wireguard-go
*version: 0.0.20250522, commit: f333402bd9cbe0f3eeb02507bd14e23d7d639280*
### Dependencies:
- `git` (1:2.43.0-1ubuntu7.3)
- `golang-go` (2:1.22~2build1)
- `build-essential` (12.10ubuntu1)
- `pkg-config` (1.8.1-2build1)
In WSL:
1. Install dependencies: `sudo apt install git=1:2.43.0-1ubuntu7.3 golang-go=2:1.22~2build1 build-essential=12.10ubuntu1 pkg-config=1.8.1-2build1 -y`
2. Clone wireguard-go repo: `git clone wireguard-go - Go implementation of WireGuard && cd wireguard-go`
3. Gheckout tested version: `git checkout 0.0.20250522`
4. Compile binary: `GOOS=linux GOARCH=arm GOARM=7 go build -o wireguard-go`
Result: `wireguard-go` binary (approx 4MB)
## wireguard-tools
*version: v1.0.20250521, commit: 0b7d9821f2815973a2930ace28a3f73c205d0e5c*
### Dependencies:
- `pfc-firmware-sdk-G2` (FW28-V04.06.01-Hotfix02)
In WSL:
1. Clone wireguard-tools repo: `git clone wireguard-tools - Required tools for WireGuard, such as wg(8) and wg-quick(8) && cd wireguard-tools`
2. Checkout tested version: `git checkout v1.0.20250521 && cd ~`
3. Clone dependencies, Wago firmware SDK: `git clone && pfc-firmware-sdk-G2`
4. Checkout required FW version: `git checkout FW28-V04.06.01-Hotfix02`
5. Setup environment: `make builder` (requires docker running, and linked to WSL2 distro)
6. Enter SDK container: `make bash`
From a parallel WSL terminal:
1. Run `docker ps` to get `` of running container.
2. Copy wireguard-tools files to container: `docker cp ~/wireguard-tools/ :/home/user/wireguard-tools`
From SDK container:
1. Find and set toolchain path: `export PATH=/opt/gcc-Toolchain-2022.08-wago.1/LINARO.Toolchain-2022.08-wago.1/arm-linux-gnueabihf/bin:$PATH`. Verify afterward by `which arm-linux-gnueabihf-gcc`
2. Enter source folder and compile: `cd ~/wireguard-tools/src && make CC=arm-linux-gnueabihf-gcc`.
From WSL:
1. Copy result back from container to WSL filesystem by `docker cp :/home/user/wireguard-tools/src/wg ~/wg` and `docker cp :/home/user/wireguard-tools/src/wg-quick ~/wg-quick`.
Result: `wg` binary and a folder `wg-quick` with multiple bash scripts.
The attached `wg-quick` script in repo is based on the `wg-quick/linux.bash` and given execution priviliges and altered to be compatible with the PFC200 distro.
## Server setup
Put files at the following locations:
- `wireguard-go` → `/usr/local/bin/wireguard-go`
- `wg` → `/usr/local/bin/wg`
- `wg-quick` → `/usr/local/bin/wq-quick `
Ensure priviliges `chmod 755` for all files above
- `mkdir /etc/wireguard && chmod 700 /etc/wireguard`
- `server-wg0.conf` → `/etc/wireguard/wg0.conf` (notice the rename)
Set privilige `chmod 700 /etc/wireguard/wg0.conf`
**Enable symbolic links**
- `ln -s /usr/local/bin/wireguard-go /usr/bin/wireguard-go`
- `ln -s /usr/local/bin/wg /usr/bin/wg`
- `ln -s /usr/local/bin/wg-quick /usr/bin/wg-quick`
**Enable autostart**
Put the `wireguard` script into `/etc/init.d/` and enable symbolic link `ln -s /etc/init.d/wireguard /etc/rc.d/S99_wireguard`
## Client setup
Put file at the following location:
- `client-wg0.conf` → `/etc/wireguard/wg0.conf` (notice the rename)
