WP400 VNC-server
I saw someone request VNC support for the WP400 some time ago, and I thought it would be useful in one of my own projects as well, so I did some research and managed to get it working using the Debian ARM64 package and libraries. I also created a plugin for WBM to make it easier to manage. WBM-plugin isnt needed tho, can be managed via ssh. Config file for x11vnc placed at /etc/x11vnc/x11vnc.conf
Tested on WP400 firmware 30.
I have not tested SSL/TLS support in x11vnc. If localhost only is enabled, the server is only reachable locally. Access through an SSH tunnel can then be used, which makes the connection secure through SSH.
