Analog filter for sensor vibration pb
Good morning,
750-890 750-455 and codesys 2.3
I have installled hydrostatic level sensor 4/20ma on a old yacht fuel tanks.
Everything is working well but as soon as the main engines are running because vibration and tanks just under, the values are moving and start to be unreadable .
Is there any filter available on codesys library (can’t find) or a way to reduice this?
I use REAL values for a HMI .
I tryed FILTER in Oscat library but for some reasons I don’t understand it is not working well.
Because I filter the Iw Inlet, I used FILTER_W but it is worth then nothing.
I tried FILTER_I and with 5 or 8 sec it is not so bad but sometime the value freeze.
Any idea to fixe it?
Thank you for your help.
Rgds
Good Morning,
Here is some function I used for filtering purpose.
It take out of the rolling average the min and max values.
FUNCTION_BLOCK fbFilter
VAR_INPUT
	rInput			: REAL;
VAR_OUTPUT
	rOutput			: REAL;
VAR CONSTANT
	MAX_BUFFER	: UINT := 15; (* the bigger the buffer is, the slower the signal will update and be sensitive to noise *)
	iIndex			: INT;
	iMaxIndex		: INT;
	arValues		: ARRAY [0..MAX_BUFFER] OF REAL;
	iLoopIndex		: INT;
	rMin			: REAL;
	rMax			: REAL;
	rSum			: REAL;
arValues[iIndex] := rInput;
iMaxIndex := MAX(iIndex, iMaxIndex);
IF (iIndex >= MAX_BUFFER) THEN
	iIndex := 0;
ELSE
	iIndex := iIndex + 1;
END_IF;
IF (iMaxIndex > 1) THEN
	rMin := 3.402823466E+38;
	rMax := -3.402823E+38;
	rSum := 0;
	FOR iLoopIndex := 0 TO iMaxIndex BY 1 DO
		IF (arValues[iLoopIndex] < rMin) THEN rMin := arValues[iLoopIndex]; END_IF;
		IF (arValues[iLoopIndex] > rMax) THEN rMax := arValues[iLoopIndex]; END_IF;
		rSum := rSum + arValues[iLoopIndex];
	END_FOR;
	rSum := rSum - rMin;
	rSum := rSum - rMax;
	rOutput := rSum / (iMaxIndex - 1);
ELSE
	rSum := 0;
	END_FOR;
	rOutput := rSum / (iMaxIndex + 1);
END_IF;
Thank you very much for your answer.
I would like to filter since iw inlet (WORD) because I’m using function blocks after (scale, linear alarms etc…) with this Iword input.
Do you think it is possible?
Do I only have to change rMin and rMax with 0 and 65535? (and of course data type from REAL to WORD)
Best regards
LJ
Indeed, if you change the variables for WORD, the system need to be modified:
VAR_INPUT
	wInput			: WORD;
VAR_OUTPUT
	wOutput			: WORD;
VAR CONSTANT
	iIndex			: INT;
	iMaxIndex		: INT;
	adwValues		: ARRAY [0..MAX_BUFFER] OF DWORD;
	iLoopIndex		: INT;
	dwMin			: DWORD;
	dwMax			: DWORD;
	dwSum			: DWORD;
adwValues[iIndex] := WORD_TO_DWORD(wInput);
	iIndex := 0;
ELSE
END_IF;
	dwMin := 4294967295;
	dwMax := 0;
	dwSum := 0;
		IF (adwValues[iLoopIndex] < dwMin) THEN dwMin := adwValues[iLoopIndex]; END_IF;
		IF (adwValues[iLoopIndex] > dwMax) THEN dwMax := adwValues[iLoopIndex]; END_IF;
		dwSum := dwSum + adwValues[iLoopIndex];
	END_FOR;
	dwSum := dwSum - dwMin;
	dwSum := dwSum - dwMax;
	wOutput := DWORD_TO_WORD(dwSum / (iMaxIndex - 1));
ELSE
	dwSum := 0;
	END_FOR;
	wOutput := DWORD_TO_WORD(dwSum / (iMaxIndex + 1));
END_IF;
You have to change the internal system for DWORD since you can add up to 15 time the WORD maximum range.
Years ago, I once wrote a filter FB with very simple code.
FUNCTION_BLOCK LowPass
Program Description:
Simple PT1 filter approximating the e-function
Y = ((X - Y) / N) + Y
Final value is reached after N cycles (limited to 5–250)
Change Index
Name: TL Version: 0.1 Date: 06.05.2017 Reason: new
VAR_INPUT
IN: REAL;
N: USINT := 50; (*Final value is reached after N cycles*)
VAR_OUTPUT
OUT: REAL;
N := LIMIT(5, N, 250);
OUT := ((IN - OUT) / N) + OUT;
