WAGO and CODESYS for Alarms Time Stamp < 10 miliseconds
Hello to community,
We have an application requirement to detect, stamp, and visualize alarmas with 1 milisecond resolution.
These alarms will come from about 40 digital inputs from a Power Station area. And other 350 I/O signals will come from the process area but with diferent requirements but not strictly 1 milisecond resolution.
Are able CODESYS and WAGO to handle this requirement? Any special configuration?
Thanks in Advance
Hello Vincente,
I think this question should be asked to WAGO Pre sales support in Germany.
The requirement are pretty strict and I won’t think it’s impossible but you may need to check the internal bus update time.
The question is different how to make sure this is 1 millisecond?
I had a project where the work of the program was lying for 10 ms. The project works, I have a question how to check exactly that the project works at such a speed? If you put a high priority and execution time of 1 ms?
