Best solution for two-way communication
I was wondering what the best practice is for two-way communication between two Wago’s would be?
I’m looking into splitting the PLC- and the HMI-program in two separate PLC’s and would need lots of variables with R/W access.
A Modbus TCP-slave on the PLC?
Use Codesys NVL lists to share data between PLCs.
Anssi
Yes, I’ve tought about that and have been using NVL, but it’s limited in size and not two-way (as per file)
Ok,
NVL is usefull for process live data exchange.
For parameterizing, Modbus can be suitable. As I can remember, also
Modbus write multiple registers is limited.
Also CANOpen SDO is for suitable for parameterizing system if CAN bus in
use.
How much data bytes included in your “block”? Binary block?
Is FTP function block familiar for you ?
Long time ago, I’ve used FTP between Wago PLC and Windows Excel.
br
Anssi
Bjørn Idar Kristiansen via WAGO Open Source Community kirjoitti
2023-09-13 09:41:
Regarding the Modbus I’ve made a “protocol” which compares structures and write changes but it is kind of heavy and was hoping for a simpler solution.
Well, it’s arrays of data structures so it would be a NVL list per object (considering the size of the structure).
I’ve not used the FTP-FB - not sure if this solution would be suitable. You mean transfering a binary file with values between the two?
If your array member fits to one NVL list, try to make a list as follows
nArrayIndex : int ; // Array index
stcObject : MyDataSetObject ;
Set array index and copy your member object in to stcObject.
Activate event trigger variable to send NVL list to others.
In receiver side. Copy data from NVL to GVL using nArrayIndex.
How does it looks like? Multiplexed method. One dataset at time.
2023-09-13 10:43:
Sounds like a feasable solution, thanks!
I will give it a try
Since Firmware 24 you can use OPC UA to Exchange Data between PLC‘s
For the HMI / Touchpanels TP600, the OPC Functions are available since FW25. (Visu-Panel and Control Panel)
The Release of FW26 will Include the possiblily to use the Datasource Manager with option „CodesysV3Application“ up to now, you can use the Datasource Manager to Connect a Datasource to a OPC-Server. (Means the plc is an OPC-UA Client)
Otherwise i would recommend to use ModbusTCP to :slight_smile:
I tried exchanging some data between two PFC200s with OPCUA but after getting all the symbols on 2nd PFC from 1st PFC (online), there was no live data and all variables with default values (0). Couldn’t figure it out so I just used NV. Fortunatelly it was sufficient for this case. But it’d be great to know how to establish such communications in the future.
Could you provide some example project for this?
Hi, old topic but a question popped up.
Do you know if there is a limit in the number of variables in a NVL?
I found in CS3.5 docs that the size of each variable cannot exceed 255 bytes, but nothing on the list itself - other than
If the size of the GVL exceeds the maximum length of the network telegram, then the data is split into multiple telegrams. Depending on the configuration, this can lead to data inconsistencies.
I think it depend on your GVL configuration. If you use the option “Pack the variables” you need a list which is less than 256 Bytes (MAX 255). If you don’t use the option, each variables need to be less than 256 Bytes. But I’ve haven’t heard about a limitation yet.
Hi, i got a project where i need to establish communication between 2 PFC, i used NVL as suggested so i am sending and receiving the data, but i also need to set up an alarm if communication is not live. What is the best way to set up check if 2nd PFC is online?
Add a counter/ incrementing value in each list - check if the value is updated or not and take actions if the value is not updated in X (milli)seconds.
I made a video on using the CODESYS V3 Application Driver. This is the simplest solution that I have found for PLC to HMI Communication.
Thanks Mike, your video saved the day.
I’m using a Maple HMI and couldn’t get a response from the Wago basic controller.
It ended up that I was missing the Username “admin” and password “wago” from the login credentials on the HMI side and your video showed that you needed them even with the TP600.
Also a couple other notes for others who read this post… for Maple HMI’s when setting up Codesys V3 communications is that it defaults to UDP comms and a port of 1740 whereas Wago uses TCP/IP comms and 11740 as the port.
JohnDitter’s document was also a good tool found in the forum here:
