Just Brough a new pfc200 750-8212
Can’t seem to connect to it through putty
I have tried the up address 192.168.1.17
I have tried to ping it through cmd and no response any help would be awesome
I am connected directly through Ethernet port on laptop to port one on the controller
Is your laptop/pc in the same subnet?
Maybe a dhcp server is running?
You can make sure its has the 192.168.1.17 when switching the switch to stop & press gently the RST button (top right corner) > 8 sec. The SYS LED will blink orange and the pfc will get a temporary address (192.168.1.17 ), until you power cycle it (back to previous IP) or modify the IP address.
I Brough the usb connection cable and set up address through the wago Ethernet app
Seems something odd was happening with dhcp
Brough the wago usb cable and connected that way and set a static up address. Seem the plc never set a ip address must of been something with dhcp
make sure a ethernet cable is plugged in, the pfc only displays the IP if it detects an uplink on interface X1 or X2
