CODESYS V3.5 SP21 Patch 1 [Fatal Error]
Good afternoon, updated the controller (FW29) and installed the new environment of Codesys V3.5 SP21.1.
After adding visualization, three mistakes pop up:
[Fatal Error] UNEXPECTED Link: ‘CodemgetContentByfirmCode3’
[Fatal Error] Unresolved Link: ‘CodemgetContientbyfirmCode2’
Tell me someone already met this?
Hello TomasD,
please check the placeholder for the library CmpCpdeMeter. It mustn´t not be resolved.
I have in your screenshot.
Hello ThomasD,
please check your entire project to see if the library CmpCodeMeter is used anywhere. The WAGO runtime doesn´t support the library. I only know the message in connection with the library CmpCodeMeter. Maybe the library is also present in your library manager but not as a placeholder, so it may be that you can´t find the library under placeholder.
My Test:
CmpCoderMeter resolved
Same Error
There was no such error before. I noticed that I have no CMPTARGETVISU library, is it needed?
I set the new Codesys and problems began. First, I wanted an old project out of 19.7 to open 21 versions. It didn’t work out for me, the same mistake. I created an empty project. I added nothing but visualization and the problem jumped out by itself.
Why do I have more pleisolders on an empty project than you have?
Hello TomasD,
it’s best to contact WAGO Support with your inquiry. I’m unable to follow you and your description of what you’ve specifically done. If you create an empty project and have no device reference, the placeholders will be added differently. Generally, the device description indicates which libraries should be referenced. I still firmly believe that you are using the library CmpCodeMeter somewhere, since the error is indeed the same as shown in my test. The library CmpTargetVisu is only needed if you are also using a TargetVisu.
I attached the project here, can you see? Thanks in advance.
Visu.project (294.3 KB)
Hello TomasD,
in the library manager of the POUs, you have still resolved the CmpCodeMeter library. Please reset to default (none).
Thanks a lot. Everything works. I did not see that there is another library in the Pou tab.
Hello? I’m Matthew from Korea.
I also had a same experience.
Now, it is work. ( It is first time to used POU tab )
I’d like to ask why this is happening. It hasn’t happened on other users’ PCs.
How can I change the default library setting in the POU tab?
Currently, when I add a visualization, CmpCodeMeter is set to 3.5.18.0 in the POU tab.
I’d like CmpCodeMeter to be set to “reset to default (none)” in the POU tab even when I add a visualization.
Thank you. I also solved same problem.
Hi, found some way to disable this library by default?
I encounter the same three errors today and follow the guide to set the CodeMeter to default.
Unfortunately, I still have the same three errors.
I appreciate any help from you guys. Thank you in advance.
See the Library Manager for the POUs
There might be one with this library that you should also reset.
