e!COCKPIT & CODESYS on the same OS
Hello
Is it OK to run CODESYS and e!C on the same operating system, or should you run them on separate systems using virtual machines?
It’s OK. I’ve been running both e!C and CODESYS on the same machine for years.
You can even have several CODESYS installation (SP16, 17, 18…) on the same OS.
CODESYS Installer makes it really convenient.
Thank you for this information. The Swedish support recommended running it under a virtual machine, but I’d rather not do that if it is not required.
I am using CoDeSys SP16 and SP17 with eCockpit (it was v. 1.10 and now 1.11) on the same machine (Windows 11) for months. Everything is going fine.
if someone wants to separate the different CODESYS versions from each other, please follow the link Installation of several CODESYS versions - CODESYS FAQ - CODESYS FAQ
