Easiest handling of OCPP?
Does anyone have experience in handling OCPP in the PLC (750-8212 or similar)?
Ideally this would be programmed directly in CODESYS V3.
If that solution doesn’t exist then some other way that runs on something like a PFC200 and is not to difficult to implement.
If someone has positive experience with some external protocol converter that could also be interesting.
(This project is for charging ships and WAGO Load Management is not an option)
I dont know of a lib for Codesys OCPP, but there are NoreRED palettes for OCPP and OCPP 2 (beta).
Perhaps you could use NR as the gateway?
