Edge computer to AWS
Running the Example program and can’t get client to connect.
Error code from Function Block is 1 “TCP_INIT_ERROR”
Have CA, CER and Keys from AWS. New to EDGE Computer.
Did these on PFC200 8212 without trouble… WBM was straight forward.
I did have to modify some permissions on the file to get a connection.
Stuck on this one. Any one else have success? Codesys 3.5.19
Hello, what library are you using? The WAGO Cloud App will not work with the Edge computers because it does not have the required services running in the background. In this case, you might want to look at the Codesys Cloud lib or the open source MQTT lib on Github.
