Wago libraries example projects
Hello people!
I am very new in PLCs and adjacent topics, and I would like some guidance.
I have a decent knowledge level in using the SCADA Ignition, but only working with EoN nodes that are other PCs using ignition, so the sparkplug protocol is being done for me.
Now I have a PFC200 RS Tele T ECO and I am trying to publish some data to MQTT AnyCloud through the sparkplug protocol. I have successfully created some tags in CODESYS on the PFC that I can see changing values on Ignition, but I would like some extra functionalities.
In, here in the ApplicationNote_Cloud-Connectivity PDF on page 57 it says to follow an example project as guideline, but that is on WagoAppCloud which is for e!Cockpit. Where can I find that project, or more info in general?
I’m using CODESYS 3.5.19.70 and everything I’ve seen so far is either for e!COCKPIT or for older CODESYS versions. Is WagoLibCloud updated for CODESYS 3.5, and where can I find it ? This has 2 .lib files inside that I cannot add as libraries in CODESYS 3.5.
Edit
Also, I’m currently using the WagoAppSparkplug library, which I think is the one I need for my project, but I would like some example projects to really see stuff I don’t know and get some new ideas.
Depending on your FW version you will need different targets:
Check under dependencies which one your need for your Firmware version.
Here are the target package with the libraries:
And here is the sample programs:
