I’m having an issue with BACnet objects. Previously, all analog values were set to zero. I manually added the points in the Client Mappings using the WAGO BACnet Configurator. The next day, after continuing modifications on the .wbc backup file and launching “Store and Download,” I received an error message, and the WAGO PLC displays a flashing code 6-10.
Please note that the project in WAGO-I/O-PRO and the SYM_XML file correspond correctly.
CoDeSys Version 2.3.9.68
WAGO BACnet Configurator Version 3.4.0.0
Could you please provide a solution to this problem to prevent the error from occurring when launching “Store and Download”?
Thank you.
Best regards,
