When I tried to log in to the WBM interface of the 750-832 controller, I received the following message: 404 Not Found – URL ‘/wbm/index.ssi’ not found on the server. I am able to ping the IP address and identify it with Wago Ethernet Settings. This occurred after performing a “format file system” using Wago Ethernet Settings.
Could you please help me by specifying the correct procedure to perform a full factory reset on the WAGO 750-832?
Should the firmware be reloaded in this case?
Thank you.
