GetScaledProcessValue
Hej,
So I am trying to figure out how to connect the getscaledprocessvalue and diagnostics to what I call xSlot : WagoTypesModule_750_450.I_Module_750_450. I know it must be a dynConfig, which is why I added xPort, but I cannot figure out how to link those to oneanother. Can anyone please help? Thank you in advance :slight_smile:
FUNCTION_BLOCK RTD_Handler
VAR_INPUT
//SensorCh : INT; //Sensor Input
ChannelNo : USINT; //Channel No
mySensorType : WagoTypesModule_750_450.eSensorType; //10=PT1000 -50°C-150°C; 11=PT100 -50°C-150°C
iSim : BOOL; //Activate channel simulation
xI : INT; //Simulated value
//SETTINGS
xSlot : WagoTypesModule_750_450.I_Module_750_450;
xPort : WagoSysModule_750_450.FbModule_750_450_dynConfig;
xSetRawChannelConfig : BOOL;
utChSettings : WagoTypesModule_750_450.typRawChannelSettings;
utRawChannelConfig : WagoSysModule_750_450.WagoTypesModule_750_450.typRawChannelSettings;
xError : BOOL;
oError_450 : WagoSysModule_750_450.WagoSysErrorBase.FbResult;
//STATE AND VALUE PROCESSING
xState : BYTE;
Overflow : INT;
Underflow : INT;
MBword : WORD;
VAR_OUTPUT
MB_Var: MB_DUT;
SensorVal : REAL;
//---GET CHANNEL INFO --------------------------------------
CASE ChannelNo OF
1..4:
xSlot := RTD_750_450_1;
//xPort := RTD_750_450_1;
//5..8: xSlot := RTD_750_450_2;
//9..12: xSlot := RTD_750_450_3;
//13..16: xSlot := RTD_750_450_4;
//17..20: xSlot := RTD_750_450_5;
END_CASE
//--- C H A N N E L   S E T T I N G S ----------------------
// 1. Read the current configuration
CASE xSlot.GetRawChannelSettings(ChannelNo, xTrigger:= GVL_Set.ConfigINIT, utRawChannelSettings:= utRawChannelConfig, xError=> xError, oError=> oError_450) OF
WagoSysModule_750_450.WagoTypesModuleBase.eServiceState.DONE :
utChSettings.eSensorType := mySensorType;
utChSettings.xEnableDiagWireBreak := 1;
utChSettings.xEnableDiagGlobal := 1;
utChSettings.xEnableDiagUnderflow := 1;
utChSettings.xEnableDiagOverflow := 1;
utChSettings.eWireMode := 1; 	//1=2-wire, 2=3-wire
xSetRawChannelConfig := TRUE;	//Read&config complete -> Trigger set
END_CASE;
// 2. Set the configuration
CASE xSlot.SetRawChannelSettings(ChannelNo, xTrigger := xSetRawChannelConfig, utRawChannelSettings := utChSettings, oError => oError_450) OF
END_CASE
IF mySensorType = 10 THEN
Overflow := 110;
Underflow := -60;
ELSIF mySensorType = 11 THEN
Overflow := 160;
Underflow := -60;
END_IF
// 3. Return raw configured value
IF iSim := FALSE THEN
SensorVal := xPort.GetScaledProcessValue(ChannelNo);
MBword := REAL_TO_WORD (SensorVal);
ELSIF iSim := TRUE THEN			//Simulation
MBword := INT_TO_WORD (xI);
SensorVal := INT_TO_REAL (xI);
END_IF
MB_Var.aChVAL := MBword;		//assign configured value to modbus channel
// 4. Return channel state
xState := xPort.GetDiagnosis(ChannelNo);
IF xState.5 := TRUE THEN
MB_Var.bChSTAT := MEM.PackBitsToWord(0,0,0,0,0,0,0,0,1,0,0,0,0,0,0,0);		//wirebreak
ELSIF SensorVal > Overflow OR SensorVal < Underflow THEN
MB_Var.bChSTAT := MEM.PackBitsToWord(0,0,0,0,0,0,0,1,0,0,0,0,0,0,0,0);	 	//Over/Under
END_IF
