Is 750-891 going to phase out soon ? and 750-8000 is the direct replacement ?
Thanks,
Regards,
Michael
Thanks,
Regards,
Michael
The 750-891 uses Codesys 2.3, and the 750-8000 uses Codesys 3.5.
750-891 cannot work with Codesys 3.5?
In term of function, 750-891 can be replaced by 750-8000?
Thanks,
Regards
Michael
Kurt Braun via WAGO Open Source Community <notifications@wago.discoursemail.com>於 2025年2月4日 週二,上午8:41寫道:
Hello Michael, indeed the WAGO 0750-08xx are only usable with codesys 2.3 and WAGO 0750-8xxx are made to be used with codesys 3.5 (PFC 100/200 GEN1 aren’t compatible codesys 3.5 but e!Cockpit only).
As a functionality, the 750-800x (750-8000 and 750-8001) can replace a 750-890, 750-891 and 750-893.
So the best for you would be to contact your WAGO rep and see with them what fit better with your needs.
