Cant find the 750-8000 in Codesys 3.5
Hi, I’m trying to connect a 750-8000 to codesys but the device only starts at 750-8110.
The Basic Controller 100 (750-8000 & 750-8001) have a separate device description in the download center. You can find it at this link: WAGO Download Center
Thank you! i can’t get it to work. i have downloaded the device description but can’t install it.
Close all CODESYS instance.
Launch CODESYS Installer (might need to be launched as admin) and click on Modify the installation, on the right side click on Install file… and select the package file.
I managed to do it. I had to change file from .package to .zip and extract. Then run SP19 to see it.
That was a lot more complicated than I expected! lol.
Thanks for your help!
my only issue now is the version!
Hello
What version of codesys you are using ?
What is the FW version of the 750-8000 ?
