Login user managment on more controllers
On a project I have 1 x an edge controller and 3 x a 750-8212.
We want to use the web visu for the visualization. We also use user management. Is it possible when we are logged in to the edge controller, and want to see a visualization of another controller that we don’t have to log in?
Thanks
By default, I do not believe this is possible. This would require centralized user management, but the built-in web-visu management is handled on each device.
One possible solution would be to implement an LDAP server.
It should be possible to link e!COCKPIT to an openLDAP server using custom libraries. If this is something you’re interested in I can send you more information on what is required.
Thanks for your answer. I am very interested in this solution.
@WagoKurt
Hello Wago Kurt
I am also very interested in this solution. Thank you very much for any information in this regard.
