Looking for Example of Native MQTT Implementation on 750-8112 (CODESYS 3.5)
Hello everyone,
I’m currently working with a WAGO 750-8112 controller and would like to send data to the cloud using the native MQTT protocol.
Previously, I was using the WAGOAppCloud library with the WAGO protocol. However, this approach has some limitations with the number of cloud tags that can be used, so I’m exploring a native MQTT implementation for more flexibility and scalability.
If anyone has an example project, configuration guide, or code snippet showing how to use native MQTT in CODESYS 3.5, I’d really appreciate it if you could share or provide some guidance.
CODESYS IIoT Libraries SL | CODESYS Store International
This license is included for WAGO Controllers, so you can you use it for free. Check MQTT Client SL library in the package
Thank You @WagoDamRud for the response. As the above license is not available free of cost, I would like to request an example code demonstrating how to send data to the cloud using the native MQTT protocol.
Its free, you have to register in Codesys Store, but it will cost nothing to download it:
Log in and then click “Download”.
Here is help and example project:
Example: Using the MQTT Client SL Library
