Hi all,
I am new to Ethernet I/P communication protocol. I have found the address of the sensor that I want to read inside the datasheet. The problem is, where do I put these address that I have found inside the Codesys in order to read the value of the sensor? I want to read value Out3 and Out6.
the sensor is a thickness measurement sensor. The data should be analog input. But after i uploaded the EDS file, the datatype is automatically is in BOOLEAN. This is the EDS file provided by the supplier. Is there any step i can do to read the thickness?
Umairyamin,
Often times EDS files provide multiple connections. According to your screenshot of the output values bytes are paired r at o your sensor value will be read as an integer. The screenshot of the variable napping you shared only consist of one byte.
Can you confirm that your EDS connection is correct for your device so you can monitor the needed values?
I followed exactly as he showed to me, and this is the result that I received. The value of the sensor should be at myValue.rOutputData right? I dont think I am getting the value that it supposed to be.
